    South Wales
    Hi could somebody please tell me if there is a way of converting widescreen vcd's, svcd's, to full screen , vcd, svcd or dvd, i can convert vcd's and svcd's with no problem at all, but would like to try and convert them to fullscreen aswell.
    Many Thanx
    Max
  2. Originally Posted by md_mushroom
    Many Thanx
    Max
    hey i know how you can do this i do this all the time i am doing it right now with the widescreen version of xXx. you will need tmpeg. thats it. ok now lets say you want a vcd in full screen ok you put vcd ntsc right ok. then where it says video file browse insert the movie. then put next and then there will be a screen that will say clip frame. where it says there check mark it then it will automatically show you the movie with the black bars on top and bottorm ok so now what you do is theres a thing in the middle of the screen that say top ok higher that and notice that the black bar keeps getting smaller. do the same for the bottom but dont hide the black bars all the way cause when you burn a vcd or svcd and play the movie it will crop out the movie a little bit so leave a little bit of the black on top and on the bottom and when you view it on your tv you will only see the movie and no black bars if you did it correct.
    Cecilio
    South Wales
    Trying out your much appreciated advice now, looks to b correct, thanx 4 your help, n e thing u need to know, if i can help i will.
    Many Thanx
    Max
  4. Max[/quote] Hey no problem right now the only thing i need to know about vcd is how to make the menu. if you know help me plz i think thats it aight peace.
    Cecilio
    South Wales
    u need to know how to make menus on vcd's ?? or dvd's ???
    Max
  6. Originally Posted by md_mushroom
    Max
    (VCDS)
    Cecilio
