  1. o.k. this is probably going to turn out to be something simple, but when i convert avi's that i have to split in the source range i get an unplayable file, but when i convert the whole thing it works perfectly but its too long for c.d. thank you for any suggestions
  2. weird
    what version of Tmpgenc do you use ?
  3. i'm using the new version, i dont understand what is wrong
  4. when you go to the advanced=>Source Range
    clic on display audio
    roll a little part of the video ... can you see some green waves (of the audio) under the picture ??
  5. Banned
    Jun 2001
    UK
    Then convert it all and split it later 8)
    TMPGEnc
    File > Mpeg tools > Merge&Cut
    Type "MPEG 1 Video CD" > Add > Your.mpg
    Edit > { start } end > OK > Output > c:\part1.mpg > Run
    Edit > { start2 end (At end) > OK > Output > c:\part2.mpg > Run
    You now have 2 .mpg files split in half
  6. Depending on what you are encoding, it is often better to set the source ranges and encode each section in turn rather than "splitting" -- especially for VBR type encoding as it avoids problematic MPEG cutting afterwards.
    What are the settings of your source file and what are you trying to make?
    In any case, since you seem to be able to encode the whole thing at once, try cutting the MPEG into two pieces. You can try using TMPGEnc (choose the appropriate setting: for standard video CD (MPEG-1 Video-CD), for XVCD (MPEG-1 Video-CD (non-standard)) and the SVCD setting for X/SVCD).
    If TMPGEnc doesn't work, try searching the forum on other methods of cutting.
    Regards.
    Michael Tam
    w: Morsels of Evidence
