  1. Most of the dvd movies I want to convert with TMPGEnc Plus will show little intervals in the motion, they have hick ups and it is not running smoothly. I discovered that it depends a little of the framerate and because TMPGEnc takes 15 frames at once to decode. Somehow it will put a little pause between 15 frames and when you see the decoded movie the little intervals will be seen when there is some motion in the movie.
    Does anyone know a solution to this problem ? I have put all other settings in TMPGEnc Plus to the highest quality but nothing works.
    Please help !
    Apr 2002
    The State of Frustration
    Is motion blur checked?
    Hello.
  3. Originally Posted by Tommyknocker
    Motion Blur ??
    There is no option in TMPGEnc Plus called Motion Blur. Can anyone help which option this is ??
