I tried to resize a mpeg file so I read some guides and it sais to use dvd2avi cause they can handle mpeg files and after that framserve and encode it again at this point I was and still am a lil confused because I dont want to convert mpeg to mpeg. Is there another way to resize a mpeg file and when I encode the file how is the quality of my new mpeg file ?? the same ?? and how should I encode 1,2,3 pass to get the same quality??
Thanks!!
Mpeg ? Mpeg 1? 2? 4?
Use TMPGEnc > Mpeg tools > Merge&Cut > "MPEG 1 Video CD" ?? > add > edit
How to resize and convert MPEG-2 file so I can work with them in PrPro CS4?
By tomchook in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2012, 12:02 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Crop/resize mpeg-2 to remove pop-up ad
By CaZeek in forum EditingReplies: 9Last Post: 8th Sep 2008, 23:43
