Hello,
I have a Dell P3 933B with 256MB ram, 40GB drive, 12x DVD-ROM, 8x CD-RW, Windows 98 SE, Nvidia GeForce 256 AGP graphics card with 32MB ram and directx 7.0. In the near future I'll be purchasing the Sony DRU500a burner to replace the CD-RW. I'll mainly use it to backup DVDs,
record CD-Rs, and backup data. Also will dabble in some basic DVD authoring. Do you folks think I should/need to upgrade directX to 8.0a or maybe the relatively new 9.0 ? I have used info/guides and freeware (
TMPGenc, SmartRipper, Virtualdub, DVD2avi, etc etc )to create VCDs, and
RealProducer Basic to creat RealAudio movies, successfully with this config. My feeling right now is to leave it alone unless a specific app requires an upgrade. Any input/comments that may save me future headaches are much appreciated. 8)
Thanks !
Yeah, that's what I thought most folks would say. I just wanted to know if there are any known issues/quirks or other weirdness that people may have experienced when ripping/burning/authoring DVDs with directX 7.0 as opposed to newer versions. Thanks for the replies so far and for any future feedback on this !
OpenGL and DirectX
By HotDamn! in forum ComputerReplies: 3Last Post: 6th Jan 2010, 01:00 -
DirectX
By CSULB71 in forum ComputerReplies: 4Last Post: 12th Jul 2009, 16:13 -
Do I have DirectX 9?
By jthompson99 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 12:44 -
How to interface with DirectX ?
By squadjot in forum ProgrammingReplies: 0Last Post: 11th Apr 2008, 22:52 -
DirectX X for XP?
By Xylob the Destroyer in forum ComputerReplies: 7Last Post: 8th Jan 2008, 17:46
