I'v set up a server to convert my avi's, the problem is that the avi wont appear in the preview and if i convert there is no picture. i think it's to do with the divx codec not being installed properly but i dont know.
Any ideas how to set the server up would be great.
2 x PIII 600 mhz, win 2000 server, savage s3 graphics .
I'm using TMPGEnc 2.5 to convert with. Works fine on my other computer but it's so slow.
When i install nimo codec pak 4 files wont install but they are protected files and are just re installed , how do you turn file protection off . media palyer wont play mpeg or avi so i think it's something to do with codecs but it has me beat.
Help a total newbie.
Thanks inadvance
