Hi
Well, there are alot of requests for I-Author I see. I have tried to go back to the URL but it is gone now. However, I have the ZIP file and the patches...thanks to some kind hearted people in the forum...Thank You!!! If you wish to have the ZIP file, please E-Mail me and I will send it but you will have to use HJ split because Hotmail accounts will not allow me to send the entire file size. Now then...if anyone knows how to convert a mpg or MPEG file to mps for I-Author please let me know, I do not want to screw up any files that I already have made. Looking forward to your e-mails.
Cheers and Thanks for all the help with the I-Author patches. Happy burning.
VH
Closed Thread
If you want to make a SVCD, use I-Author's multiplexer. If you want to make a VCD, convert the mpeg to .mps with mpgXmps.
For Zed:
Zed..I am wondering if there is a difference between regular I-Author and Deluxe versions. Surely there must be. I agree the link would be much better and easier to provide rather than HJ workarounds. Tell me, how have your VCD/SVCD(s) come out using the program..tonight will be the first night I have used the program...any pitfalls to beware of? Any time saving advice you can provide to a ROM burning soul in matrix love?
VIDEOHOUND
TO be honest I have not used it, I installed it and had a quick look at it but have never used it to create a VCD - I am currently using the VCD Toolkit and have found it to be good enough for what im doing (a vcd photoalbum) so have stuck with it. I believe the difference between deluxe and standard version of I Author is that the deluxe lets you do SVCD and the standard only VCD (I think..)
I will be interested to hear how you get on with it.
regards
Zed
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
how to author a CD?
By michcio in forum Authoring (VCD/SVCD)Replies: 4Last Post: 2nd Sep 2008, 13:06 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
re-author a .vob
By forare in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2008, 01:20 -
seems to author twice
By BroomQueen in forum Authoring (DVD)Replies: 7Last Post: 15th Oct 2007, 08:22
