I've only just started to use this encoder and I'm having a small problem:
When encoding to DVD with the preset template..... I am unable to get the completed Mpeg into SpruceUp......... Get some kind of Stream error reported ?
I can adjust various settings within the template..... Its just that Im not too sure what I need to change.
All in all its a Very quick encoder...... On my current system I can encode to Full D1 DVD in real-time.
Thanx![]()
I agree MainConcept's mpeg encoder seems to be faster and it's got more options to fool around with but...
I've had a somewhat similar problem. When I burn a VCD using Ulead DVD MovieFactory 1, near the end of the process, I get an error that says something like... "Generic error... make sure the system is ready for use". If I burn a different file I get no error. This is only happened with some mpeg files encoded with MainConpect mpeg encoder.
Anyway, I'm guessing you've never had problems with SpruceUp until you started encoding with MainConcept right?
In any case, try updating MainConcept's encoder... I believe the new version is 1.3 or something. They fix a lot of things dealing with DVD's.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 20:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56 -
MainConcept H.264 Encoder Error
By cowboysroy31 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2007, 19:06
