hey, does anyone know how to convert mov to mpeg2? i tried tmpg, but the mov files don't open.
thanks.
The Convert section says this:
To convert from QuickTime MOV videos you must download the QTReader.vfp and copy it to the TMPGEnc folder.Hello. -
thanks, do you know where i can find this? i searched in their homepage and couldn't find it.
i did that, but the mov still doesn't open. do you know any other program that can convert the mov to meg2?
I had the same problem and now it works. Did you copy the file in your TMPGEnc directory?
I'm using TMPGEnc to do this, work great on small MOV files, but then I try on a 9 mb or bigger it only to about 50%. Then it crashes.
Does it convert in realtime?
I'm using a:
PIII 600
128 ram
TNT 2 grafick cardFaster than a shark!
QuickTime MOV to MPEG2 too dark
By bgtrix in forum Video ConversionReplies: 1Last Post: 16th Mar 2012, 12:36 -
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22 -
Problem with converting MOV to MPEG2
By encAmateur in forum Video ConversionReplies: 5Last Post: 18th May 2011, 03:56 -
MOV to MPEG2
By 6079 in forum Video ConversionReplies: 0Last Post: 3rd Sep 2010, 06:28 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42
