  1. Is it possible to convert a PAL .mpg to a NTSC VCD? I live in America and dont know if my DVD player can play PAL or not. My source file is in PAL format I guess, Vdub said it has 25 frames per sec and the resolutoin fit that of a PAL format. Any advice on what to do?
    Apr 2002
    The State of Frustration
    Hello.
  3. Banned
    Jun 2001
    UK
    You will never know if it wont play them "Until you try"
    whats the cost of 1 disk to try a PAL VCD ?
