  1. Using dvdxcopy I copied some of my movies. I thought everything was going great. Then I sat down to watch a movie and about 1/2 way through the pixelation started and it kept getting worse until the movie was freezing up for a second then restarting. I put in 2 more movies I had made with the same results, perfect until about 1/2 way through. Any thoughts?
  2. Does the same problem exist if you play it on your PC DVD-ROM? if it pays ok on your PC I would first suspect the media you burned to. Is it cheap media?
    Is it DVD-R or DVD+R? I've got a Sony DRX500ul and cheap DVD-R won't play on my DVD players but play fine on my PC DVD-ROM. Higher quality DVD-R plays on both. So does DVD+R.
  3. Must be either your burner or Media with your burner, I have the HP DVD200i use $2 riteks and made about 50 DVD backups using this software burning up to 4.5 gigs worth and played them on 10 different DVD palyers and they play perfect. even sometimes having to split real long movies into 2 discs, still no problem.
