I am experimenting with trying to create DVD compatible files from my DV camera using TMPGEnc and ifoedit. When I create either mpg files or split m2v and wav files using TMPGEnc they seem to playback just fine in Media Player or WinDVD respectively. However when I use ifoedit to create DVD files to burn, the files playback in Jerks. This occurs off the hard disk version or of a CDROM.
If I use half D1 sized files, ifoedit just crashes...
Can someone tell me what I am doing wrong?
Am I using the right tools? I want to be able to put as much as possible onto a DVD+RW disc or onto CDROM.
jacko123 -
I am in about the same situation - using TMPGEnc and Ifoedit
to create DVD-R from a DV camera - and I am having
the same problem with jerky playback of IFO files.
The files created by TMPGEnc (m2v and wav) play back
fine for me too in WinDVD.
Did you ever find a solution ?
If I ever get it figured out, I will post my solution.
Thanks for any suggestions.
Joboshare dvd copy produced a bunch of files I dont understand
By rocks911 in forum DVD RippingReplies: 1Last Post: 31st Aug 2011, 22:38 -
BDR produced on a 4.6 GB file...fritzi?
By New Bee in forum Blu-ray RippingReplies: 9Last Post: 4th Feb 2011, 11:38 -
FLV to MPEG conversion results in no files being produced
By mendojazzhead in forum ffmpegX general discussionReplies: 5Last Post: 16th Feb 2010, 13:23 -
FLV files play jerky/skip every few frames
By Madasarat in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2008, 02:20 -
hd video files are jumpy / jerky
By adamvfb in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2007, 13:12
