Hi,
I'm using Uleads VideoStudio6 trial to produce the Mpeg2 file, which plays perfectly on the computer. When I burn it to DVD with Mirror DVD-R writer three quarters of the way through the audio begins to go out of sync to the video. the second DVD had audio and video out of sync from the start.
Anyone got any ideas whats happening?
Bill
I had the same problem with Video Studio lately as well. I ended up using Gold Wave to resynch it. You have two type of audio synch problems:
Gradual audio synch -- try this guide
Static audio synch -- Try this guide.Hello. -
Hi Tommyknocker,
Sorry, I didn't make myself clear. The Mpeg2 created by VS6 is fine, its the DVD burnt by the player which has the audio out of sync, but again only about three quarters of the way through.
Bill -
I know what you are saying. But if you want your DVD to be in synch, you will have to make your input video out of synch by an inverse amount. That is if your DVD audio trails the video by two seconds, make the input video's audio lead its video by two seconds. Therefore, canceling the error out.
Hello.
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 14:50 -
Audio (or video?)out of sync when burned
By seragx99 in forum Authoring (DVD)Replies: 2Last Post: 28th Jul 2008, 07:05 -
How do I change audio codec on an already burned dvd/video converted file?
By klobb in forum AudioReplies: 5Last Post: 31st Dec 2007, 05:03 -
Audio Sync problems with MKV file using WMP
By jradams76 in forum Software PlayingReplies: 0Last Post: 23rd Jul 2007, 11:51 -
Merged file audio sync problems!
By leedownen in forum EditingReplies: 5Last Post: 14th May 2007, 01:37
