    Dec 2002
    Rochester, NY
    Can somebody help me out on what all settings should be with making a svcd in tmpge, starting with temp. etc....... so nero will stop complaing that the file is not svcd comp. even though im sure i did it right
    thank u
    Apr 2002
    The State of Frustration
    1. Open TMPGEnc. For input video select your video file. If you do not have audio synch problem go to step two. If you do have audio synch problems, use this guide.
    2. Select Load. Select the SVCD template, then Okay.
    3. Select Start. The resultant file should be SVCD compliant and Nero should have no trouble burning it.
    Hello.
