I got crash all the time and i have to plug off the AC cable (i cannot delete anything) tryng to clean my trash basket. There are 8 gb on vob, m2v files.
I got this post : http://www.vcdhelp.com/forum/viewtopic.php?t=134519&start=0&postdays=0&postorder=asc&highlight=
calling Mac won't let me delete a 4 gig mpeg file!!! Help!
but im totally noob on OSX and MAC sistem. Can you guys help me on this
THANKS!!!!
dunno where and what is terminal, and I don't know os9.2
Just passing few days a go on MAC OSX from PC....
CIAO![]()
Results 1 to 9 of 9
That is a kernel panic (unix crash). You could spend hours (or days) trying to figure out why it's happening. I would suggest just reinstalling OS X (with the archive and install option if you have 10.2).
Reinstalling may be a little drastic.
It seems from the photograph that there is a Symantec kernel module in the backtrace. So I would make an educated guess and say that some Symantec products causes a kernel panic when you try to delete large files.
I would simply suggest removing Norton or any other Symantec product before doing this, or maybe uninstalling it.
BTW, the terminal is in /Applications/Utilities and is called Terminal.app.
It gives you an Unix shell (command line tool) that is the equivalent of the PC's cmd.exe (or command.exe or DOS mode, whatever). -
Tnks, let me revove first the Symantec product,as norton firewall antivirus etc.
Hope is working
bye... -
Tix,
I agree with Iga -- no need to reinstall 10.2 for this problem. It is possibly related to Norton utilities (I've experienced the same kernel panic under the same conditions). I have Norton installed. Although I tend to wonder if QT6 might be a root cause for this problem... (I've noted no trouble deleting these large files prior to opening them in QT).
You cannot force-empty the trash from the terminal (even as the root user). It will result in a kernel panic. At least this is what I have experienced.
One solution that does work (for me) is to boot up in OS9 and then move the large mpeg file(s) to the trash from there -- and then empty it from OS9. This works -- although it isn't exactly a clean solution...
The other option, as Iga suggested, is to blast Norton from your Mac. I have not gone to this extreme.
DVDM 8) -
oK DVDM, the problem is gone. Now my mac feel fresh and clean
the trash bin was full with 56 GB of garbage!!!!!! and just 4 GB free!!!
now I can work again. Tnx an +K for you guys !
I think I dont need anymore Norton Programs on My G4!
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
Video Noob - how to create dvd for dvd player from avi, flv files..?
By acegap in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 07:10 -
Noob Question: What subtitle files do I choose/use for DVD player
By peggypwr1 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Mar 2009, 16:24 -
Real noob question about DVD Movie files
By Thom Yorke in forum Newbie / General discussionsReplies: 3Last Post: 25th Feb 2009, 11:50 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38
