  1. I want to capture a 120min movie and turn it into a VCD without loosing to much quality, but i only have 5 gig of space avalible.
    Can sombody recomend a codec (and settings) that will give me a good quality with a resonable file size?
    I prefer vertual dub, if i use the hyfu codec i lose about 3% of my frames(good) and with everything else its like 99% and bad quality. Divx low-motion gave good size and quality but the output was jumpy because of loosing frames!!!!!
    I have:
    PII - 500 MHz
    128 mb RAM
    13 gig drive with 5 gig for this project
    The movie is:
    Animated
    1/2 - Dark action
    1/2 Bright action
    Always action
    Hop thats everything u need
  2. Motion Jpeg is going to be your best bet. Try a Quality 18 setting. With 5 Gigs you might have to lower the setting to 15 or 16.
