Hi
I recently changed my motherboard from a ECS K75SA to a MSI KT3 Ultra.
I don't know if that is a relavent issue but my recording of sound from line-in (via SB Live 5.1) has now become a little crackly.
Recording from wav is fine.
Line-in sound is fine b4 I record.
Does this point to a problem with my hardware or the lead I am using??
I never had this problem b4 changing my MOBO but I have also moved my computer in the room.
Maybe I damaged the lead.
But would this cause .........
PLAYBACK = Fine
RECORDING = Crackly
Any ideas appreciated.
Cheers
Fozzee
Does it have a VIA chipset?
Panasonic DMR-ES45VS, keep those discs a burnin' -
Blimey 2 minutes and a response.
Yes it does.
Your comment sounds ominous
Can you help??
Fozzee -
There are known problems with via chipsets and them interfering with certain operations like recording. What I have heard is make sure you have the very latest drivers and check for issues on mobo sites etc. (this site is good but does not specialize in this area). Hopefully a software patch will fix it.
Sorry dude (mate?) - you might try a hw forum like http://www.hardwareanalysis.com/content/forum/12/ to find a Via guru. Heck, I've been known to be wrong
I'm also having this problem. My video looks fine, but my sound is really crackly. Sometimes the crackle doesn't sound that bad, depending on the show/channel, but it's always there.
Alternate Ways to Line-In Recording
By darkdestiny in forum AudioReplies: 31Last Post: 8th Feb 2012, 09:47 -
How to permanently set Recording Control Line In setting
By c627627 in forum Capturing and VCRReplies: 1Last Post: 13th May 2010, 21:10 -
How do you have line-in audio play without using recording software - near
By yoda313 in forum ComputerReplies: 2Last Post: 9th Jan 2010, 18:45 -
multiple line input on pc - recording radio
By straighjacket in forum AudioReplies: 1Last Post: 8th Feb 2009, 16:36 -
Line in Microphone recording problems
By sara82 in forum AudioReplies: 3Last Post: 10th Jun 2008, 16:53
