I converting an avi to mpge with virtualdub the movie is blochey is there a way to fix this?
What u mean blochey? is it too blocky? or is there new blocks of colour? describe the problem more........
yes there are blocks of colour. When I play the movie with divx its fine but when I try to watch on a dvd player its has blocks of color
If its purple, in TMP go to options, environmental settings, VFAPI plugins and reset priority on Direct Show Multimedia file reader to 2 not -2 try rencoding small part of movie burn to CDRW and preview on dvd player, purple gone..... if its green or mushy try reinstalling codecs, best way Ive found so far:
[quote="narked"][quote="crack_man"]NOW I know the solution to this shit.
I uninstalled all DivX codecs and xvid codecs.Then I Installed only xvid to test if it worked and it did but with no sound cause it had ac3 sound.
You can install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then I installed all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that I installed Nimo Pack but unchecked all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow 2002-04-19. Install Nimo from here:
http://www.btinternet.com/~nimosiro/
Now all should work fine!
