Hi I'm trying to convert an avi file to mpeg 2 using TMPGEnc with the normal settings I always use (which has always worked), but the end mpeg file has no sound.
I tried using honestech mpeg encoder 3.0 and LSX Mpeg Encoder, and get the error message "encoder can accept only uncompressed 8- or 16-bit PCM audio sampled at 11.025,32,44.1, 48KHz).
I don't understnd the error message, is there a way of solving this issue to allow me to convert the avi to mpeg?
Use VitualDub to save out the audio as uncompressed wav.
www.vcdhelp.com/divxtovcd.htm#audioMay the force be with you. -
Then maybe the source is using a audio codec you don't have ?Originally Posted by momo101
vdub > file > file information
What's it say ? Unknown ? = AC3
Also..
TMPGEnc > Option > environment settings > VFAPI plug-ins >
Right click "DirectShow multimedia file reader" > select higher priority
do it several times until its at the top with a value of 4
Compressed Too Small?
By OutOfBreath in forum Authoring (Blu-ray)Replies: 5Last Post: 4th Nov 2011, 18:41 -
M4V to AVI in VD, when compressed with Xvid, saves with audio out of sync
By kiki hayes in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2011, 09:45 -
Which is least compressed format?
By vid83 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 19:59 -
AVI and compressed 5.1
By cyanyde in forum DVD RippingReplies: 13Last Post: 2nd Jun 2008, 15:06 -
compressed capture with composite
By benaw in forum Capturing and VCRReplies: 2Last Post: 20th Nov 2007, 08:09
