  1. Does anyone know why my colors suddenly turn pinkish in virtualdub.
    I never had this problem before.
  2. I fogot to mention that when playing with Windows media player i don't have those pinkish colors.
    And the color is not always that way, sometimes its good, and then it turns into this gay thingie
  3. Banned
    Jun 2001
    UK
    Do you have the SMR (Angel portion) codec installed ?
    you do ? get rid of it
    file > file information
    What codec is being used ? xvid ?
  4. I deleted nimo codec pack and reinstalled div3alpha and colors are back to normal
    btw , it was Video Codec: DivX 3 Low-Motion
  5. Banned
    Jun 2001
    UK
    You should also run "Ad-aware" to check your system for spywear, Nimo may have put some on your system.
    http://www.lavasoft.nu/index.html
  6. thx I'm clean again, i hope
