  1. I have a TerraTec TV400 Tuner card, what is the best compression
    to use vhen capturing, and if I don't have where can I get it?
    Thanx
    Krebsen
    Dec 2002
    Huffyuv is you has space and speed, you can exceed 20 Gb/hour. MJPEG at 80%-90% can hit 4-8 GB/hour. All this depends on your resolution, these numbers are for SVCD like resolution.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
