My Hauppage WinTV Nova-T digital TV card is not recognised as a capture card by any program (eg Virtualdub), and is listed by Device Manager as a network card. Tried every program available...
Normally files are saved as mpeg2's, but I have found them impossible to edit - even a simple cut/joint leading to out-of-sync audio. Again, tried every editing program available...
Is there a way of saving to AVI, or should I invest in a standalone DVD writer such as the Philips 880?
This problem is now into month 3 - and all I want to do is record widescreen digital TV films and trim the commercials etc. and have invested over £600 in the project. HELP!!!
Results 1 to 1 of 1
Regards
Colin Gavin
No sound in WME with USB capture card
By bomb jack in forum Capturing and VCRReplies: 2Last Post: 25th Feb 2011, 04:40 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2010, 06:50 -
Advice on capture card pci express or usb, for windows 7, umcpmpressed avi
By victoriabears in forum Capturing and VCRReplies: 12Last Post: 1st Aug 2010, 14:39 -
EasyCap USB to S_Video Adapter Capture Card
By domainbug in forum ComputerReplies: 3Last Post: 7th May 2010, 21:51 -
USB 2.0 Video Audio capture Card
By jj3502 in forum Capturing and VCRReplies: 0Last Post: 3rd Feb 2010, 05:09
