I am in need of some help to get the right settings to create a DVD2AVI project and send it through TMPGEnc, with the final result being a MPEG2 file.
Is someone has done this before, could you enlighten me as to the settings you have used? I have tried several rounds and have yet to discover the right combination to generate an acceptable picture.
So far, I've found that I have to set 'Field Operation' to 'Forced Film' in DVD2AVI -- otherwise the ending video is really choppy. Beyond that, I am not sure what other settings really effect the project.
In TMPGEnc I am using a 2 Pass VBR with a low/high of 0/9800 and am playing with the average (5000-6000 probably in the end). Under the Advanced tab I have 'Noise reduction' checked, but that is it.
Does anyone have any suggestions for some other settings I can try?
Many thanks!!
Hoag
Is that in DVD2AVI or TMPGEnc? I looked in both but couldn't find anything that was exactly that.
Can you point me to the right menu?
Thanks!!
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 22:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 09:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 08:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 11:52
