BURNER: sony dru500 firmware f
Burning Prog: NERO 5.5.9.17
what i did:
Disc was 2-layer, but i only wanted first half, so I ripped DVD
with smartripper, choosing chapters 1-12 and the ending result is 3 VOB files ripped onto computer.
then I redid the IFOs by using IFOEDIT 0.932.
then use Nero to burn.
when playing on dvd standalone player, it just sits there and lags at random tracks. for that particular disc it was track 2 and 6. The rest were ok.
NERO however did pop up a message saying there could be a problem with the burn, but I assumed it was nothing. What could be the problem?
Is it Nero?
my way about doing it?
IFOEDIT?
never had the problem you are having but i use ifoedit vs 0.94, you could try this and see if the prob goes away.
Conversion of .TS to .MPEG2 causing problems
By DirtyMetis in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2011, 11:10 -
Changing the order of chapters in idvd
By caspera in forum MacReplies: 3Last Post: 16th Sep 2009, 01:34 -
Subtitle restarts when changing chapters
By felipefrog in forum Authoring (DVD)Replies: 1Last Post: 15th Dec 2008, 08:54 -
Besweet causing problems?
By hardcorejason in forum Video ConversionReplies: 1Last Post: 27th Apr 2008, 13:59 -
How do I, add chapters in Nero causing sync problem
By breeze9 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2008, 06:37
