I am having a problem viewing some divx files. I downloaded these eps of buffy and when i play them the screen is green. There is sound, but just a green picture.
They have [AC3]_[XviD]_[FoV] in their names. I downloaded the latest nimo and other codecs.
Any idea why i still have a green screen
P.
Do you have the xvid codec installed, if not you can get it here.
http://www.xvid.org/ -
NOW I know the solution to this shit.
I uninstalled all DivX codecs and xvid codecs.Then I Installed only xvid to test if it worked and it did but with no sound cause it had ac3 sound.
You can install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then I installed all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that I installed Nimo Pack but unchecked all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow 2002-04-19.Install Nimo from here:
http://www.btinternet.com/~nimosiro/
Now all should work fine!
By the way,AC3 comes with the Nimo Pack. -
If you use ffdshow, be sure to use latest one cause some older have the greeen bugs. http://www.doom9.org/software2.htm#filters
Green Screen Advice
By HoosierGuy in forum Newbie / General discussionsReplies: 19Last Post: 8th Mar 2011, 09:53 -
How to use green screen with video?
By MitchStevens in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Jun 2009, 10:44 -
Funny green screen
By timmythesaint in forum Newbie / General discussionsReplies: 18Last Post: 14th Apr 2009, 15:41 -
Screen turns green
By boysha in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 14:46 -
green screen in convertxtodvd
By fruitpassion in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jun 2007, 01:16
