  1. Hi! Okay...I used Nero to burn music videos of Kazaa to a VCD. I know for a fact my dvd player reads vcd's for I have tested it before. However it does not read the ones I created using Nero. The program supposedly finishes burning the vcd but later, once I open up the CD drive to see what's in the cd nothing is present! I don't understand why nothing is being transfered to the cd. The dvd player interprets there is not disc present. Am I supposed to use cd-r or cd-rw to burn the disc on? (by the way, that's what I've tried so far) Please help me! I've been trying for two days without any results! Thank you!
    Jrock
  2. Member Conquest10's Avatar
    Chicago, IL
    i had something like that happen to me with a couple of discs before. i had no idea what was wrong. i could read it on my computer but everywhere else it said the disc was empty.
  3. The problem is even when I open the suppossedly successfully burned vcd there is nothing in it! I put it in my dvd player and it says "no disc inserted" and then it ask me to put in a disc. Please Help! I'm really getting frustrated...thanks again.
    jrock
    Jan 2003
    London, England
    Try using VCD easy to burn your disc instead. Its better then NERO.
    Politeness does not mean you are weak. It means you are strong enough to deal with rude people.
