I have tried several times to separate the audio and video in the Gladiator into separate files with SmartRipper, but it just does not seem to be working. I followed one of the guides (Newbie DVD2DVD-R) located on this site in an attempt to do it, but no luck. I have used SmartRipper before, but never to separate the files and have had tremendous success with it. However, I recently purchased a DVD Burner, so I would like to burn as much of the DVD's qualities onto a DVD-R. These are my setting in SmartRipper:
Stream Processing-
Enable Stream Processing = checked
Video NTSC = checked
Audio English AC3 (6 ch) = checked
Audio English AC3 = unchecked
Subtitles English = unchecked
Other = checked (no reason (did it with and without)
ID=0xE0-
Demux to entra file = checked for all the selected items above.
** went back over each one to ensure that "demux to extra file" was selected.
I then click on Start and let it run for about 2 hrs. After that period of time I have the mv2, a set of VOBs, IFO, d2v and prv files, but no audio file. Can anyone tell me what is wrong here or how I can accomplish this using a another method or another ripper. Thanks in advance.
surferr
Results 1 to 1 of 1
HELP! This is all new for me. Edit 2 separate minidv audio/video files.
By nexgraphics in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2009, 10:45 -
Sample error on separate source means video & audio out of sync!
By christowe in forum MacReplies: 3Last Post: 13th Jan 2009, 14:22 -
Extracting/demuxing a .TS into separate video and audio files?
By mkvbob in forum DVB / IPTVReplies: 10Last Post: 25th Jul 2008, 03:15 -
converting format using separate video and audio files
By joshua4 in forum Video ConversionReplies: 4Last Post: 11th Jun 2008, 04:09 -
All of a sudden separate audio & video files
By amigasteve in forum ffmpegX general discussionReplies: 6Last Post: 16th Dec 2007, 17:59
