hi there
i have burnt things before to vcd sucessfully but now get this Nero window that opens up when i have dragged my mpeg into the vcd burning option.
the following problems were found:
stream encoding which is invalid for a (super) video cd
invalid audio stream 48000hz 2 channels
which leaves me 3 choices:
turn off standard compliance and continue or re-encode the video file or cancell
i'm using xp and Nero 5.5.9.17
any one got any ideas ?
i noticed that if i chose the Nero re-encode option ,it dropped from a 500 meg file to a 300 ,so i gathered that it loses heaps of quality
thanks in advance
VCD & SVCD require 44.1KHz audio. 48KHz is for DVD.
You may need to reencode your source. Do not let Nero do this as the quality is crap. Also if you check noncompliant it may not play in most players.Panasonic DMR-ES45VS, keep those discs a burnin'
Joining HD MOV files from camera & saving as mp4; "Invalid Audio Stream"
By maskingtape in forum Newbie / General discussionsReplies: 30Last Post: 23rd Aug 2011, 13:30 -
Eac3to "Clipping Detected...2nd Pass" --> Avi2DVD finds no audio stream
By Murk in forum AudioReplies: 4Last Post: 5th Aug 2010, 17:27 -
My DVD backups are "invalid" in Sony Blu ray player
By KeithMckane in forum Authoring (DVD)Replies: 6Last Post: 26th Feb 2010, 16:11 -
HCenc "Invalid MPEG-2 Frame rate" error.
By Maikeru-sama in forum Video ConversionReplies: 24Last Post: 8th Jul 2008, 19:09 -
Philips DPV-5992 not recognizing a USB HD - "Input Invalid"
By benvid in forum Newbie / General discussionsReplies: 6Last Post: 21st Jun 2008, 18:02
