I've been having some strange problems with playback of 720x576/704x576 PAL mpeg-1's on my Hollywood plus card (DXR3 - both creative and original software).
An offset part of the green signal (and some of the red & blue), flashes on top of what seems to be an otherwise ok picture.
Encoded with TMPGenc, I first though the file itself was garbage, but testing it on a standalone, the resulting picture was fine.
The strange thing is that the closest corresponding NTSC resolutions does not exhibit this problem when run through the card.
Due to an excruciatingly slow machine, I haven't really been able to investigate the extent of this problem, but found that 640x512 worked fine.
Anyone else come across this?
- Bingo
Results 1 to 1 of 1
Help finding an AviSynth deblocking filter that works at high resolutions
By Cman21 in forum EditingReplies: 17Last Post: 9th Nov 2010, 06:30 -
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 14:21 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Monitor split for high resolutions? (KVM)
By lordsmurf in forum ComputerReplies: 9Last Post: 5th Dec 2007, 15:30 -
Non-compliant resolutions (DVB & SATV)
By DRP in forum Video ConversionReplies: 12Last Post: 1st Oct 2007, 14:48
