hey any one couls help me with this problem. i have this movie but i cant play it it has audio bit rate 512kbps audio sample size is 16 bit audio format is PCM and a video frame rate 15frames/second data rate 6kbps video sample size 24 bit and a video compression MS-MPEG4 V3 so what software or codec can i use to play this can i use to play this movie please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![/b]
hey zup guys!!
Divx mpeg 4 codec
Why worry about one codec install them all. The most stable way I've found so far (respect to crack_man) is:
1) Install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
2) Then install all DivX codecs(3.11 alpha, 4, 5.02) separate (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
3) Then install Nimo Pack but unchecked all divx codecs and the xvid codec Make sure ac3 sound is checked. Install Nimo from here:
http://www.btinternet.com/~nimosiro/
