When I analyze my mpeg2 file in VCDeasy i get these warnings:
mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.1e]
mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.0d]
mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:01.1e]
mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.10]
etc....
Does anyone know what they mean?
VCDEASY churns out lots of warnings.
For the most part,just ignore them and everything will be fine.
Is your VCD burning OK ?
I think many of the warnings are geared to the fact that some burns may be of the non-standard variety."Today is only yesterdays tomorrow" -
TMPGEnc doesn't up the correct offsets in the MPEG-2 file for SVCD (rather, it uses the CVD style offsets).
To fix this, either use bbMPEG to remux first, or set VCDImager to "update scan offsets" for the MPEG-2 files.
Regards.Michael Tam
w: Morsels of Evidence
Test warnings
By alfresco in forum TestReplies: 3Last Post: 1st Feb 2010, 06:35 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 14:48 -
Are there any players/firmware hacks to allow skipping of warnings/preview?
By Sephiroth666 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 14th Mar 2008, 08:37 -
Laser printer warnings?
By Bartron in forum ComputerReplies: 8Last Post: 8th May 2007, 13:07
