Has anybody successfully played a DVD+RW disk on the Panasonic DVD-CV52 stand alone player and if so what program did they use and what settings to burn it.I am using a Sony DRU-500A to burn.
I ask because I bought the Panasonic based on the info in the DVD players list on this site which says the Panasonic CV52 reads +RW,but i have tried several modes with Nero and it won't read.Please help.
What I do is make an image either in DVDMAESTRO or IFOEDIT mount the image in Daemon tools and do a dvdcopy using NERO. This method I found out works 100% on my Go Video my Panasonic and Toshiba DVD players.
Thanks for the reply NYPlayer.
Can i make the image from a dvd ripped onto my hd or only from anoher disk -
You can make an Image from your authored files on your hardrive. In DVDMaestro you can make and image from your VIDEO_TS folder on a hardrive also you can use ifoedit.
When i browse to my my VIDEO_TS with the authored files in, it Dvd maestro starts and comes up with mesage " Creating udf volume structure... no files found to compute image process cancelled !.
Even though all my ifo,bup and vob's are i the folder.
Any ideas please?
AVCHD Disk on Panasonic DMP-BD60
By rjesse in forum Authoring (Blu-ray)Replies: 12Last Post: 7th Apr 2010, 10:21 -
How to burn DAO data disk
By logannsan in forum ComputerReplies: 4Last Post: 22nd Jun 2009, 13:17 -
Ripping a +R disk from a Panasonic DMR-es25
By schematic2 in forum DVD RippingReplies: 7Last Post: 23rd May 2008, 02:01 -
Burn in Disk Utility
By andredanton in forum MacReplies: 4Last Post: 12th Feb 2008, 13:41 -
Panasonic ES35 cannot read disk.
By mable91367 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Jul 2007, 16:10
