ive tried my dvd, ulead video studio,Capwiz and they all capture video and audio nicely but of course the audio is a few millsecs off and as the file gets bigger its(audio) off more. Using DVD maestro for authoring and using the audio sync track function, but it doesnt work with the capturing process. Maestro will sync track when ripped from a dvd but not when capturing.
How do i get the da$%^m audio synced back?
any help would be appreciated
Have your tried capturing with VirtualVCR or VirtualDub. Both work for me except VDub will only capture at 640x240, so I use VirtualVCR. Both are free.
http://www.virtualdub.org
http://www.digtv.ws
Try 'em .. -
a no go with vdub and v-vcr. vdub wont recognize my ads stream machine capture box and v-vcr wont allow me to select the "video" button in settings. when i get to that button it errors out and closes the proggie.
running winxp so maybe that is the problem.
thanks for your help, maybe ill get a few more clues -
You might want to do a test capture using MPEG2 and see if A/V sync problem is also there. If no sync problem occurs, then you will have to try other prog for caturing.
I tried every piece of software any one could think of due to the same problem. And I'm talking about DV captures from a camcorder.
I finally tried the capture program built into Vegas Video 3 (using upgrade patch too). BINGO!!!
I can capture 9 hours of video continous and NEVER lose sync now. It's so good is scares me.
I'm afraid to disconnect the cables now for fear I'll change something
I just ordered a Canopus ADVC-100 so I can use my Sony DV for it's intended purpose again. I only hope the ADVC-100 does as well at the Camcorder is doing now.
Try Vegas Video and see what happens. It's not cheap mind you, but I think they have a demo, or a lite version you could use just to test it out.
I sure made my life happier so far...
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
[Audio] Capturing, editing, keeping a/v in sync and dynamic resampling
By rmdeboer82 in forum Capturing and VCRReplies: 1Last Post: 20th Mar 2011, 15:16 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14 -
capturing using different compters for A/V = mux drift/sync issues
By drstrust in forum Capturing and VCRReplies: 4Last Post: 17th Nov 2007, 09:13
