Results 1 to 14 of 14
  1. loveo!
    I would like to request help on how to change
    a video in vcd format to mp3.
    Please assist. Thank you.
    Jul 2001
    los angeles
    You cant convert video to mp3. What you might mean is converting the video to divx (video + audio). Or ripping the sound from a vcd, and converting only the sound to mp3 format. Please be more specific, and make more sense when asking your question.
    Aug 2001
    Bay Area California
    How would you convert VCD audio to MP3?
  4. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
  5. I am looking for instructions on converting vcd to dvix could you please help? Graham
    [/quote]
    Feb 2001
    Berlin, Germany
    Convert the VCD .dat file to .mpg with VCDGear, demultiplex the .mpg with TMPG. Convert the .mp2 to .mp3 with LAME, maybe you have to create a temporary .wav file, this can be done with TMPG.
    Feb 2001
    Berlin, Germany
    http://www.vcdhelp.com/avi2divx.htm
    http://www.vcdhelp.com/vcdtools.htm
    VCDGear converts VCD .dat files to .mpg
    VirtualDub converts MPEG-1 files to AVI. If you want DivX, you need to install a DivX codec.
  8. Yes i would like to convert only the sound from a vcd to mp3. Is that possible? Thanks a lot!
    Feb 2001
    Berlin, Germany
    I think, I answered this already. See above.
  10. Truman,
    can u suggest me other tools beside vcdgear cause i cant seem to open the file after i downloaded it... and it's like 100k file only.. when i execute it.. a dos promt came out.. then it automatically exit after 1 sec!
    Aug 2001
    JERSEY
    just use tempge to demultiplex then use a sound editer to convert to mp3
    Feb 2001
    Berlin, Germany
    pillowman, there is also a VCDgearGUI available. You don't need to work with the command line console.
  13. to open a ms-dos program in windows, you can't just double click the file (that's what guis are for )...
    at the startmenu->run type: command
    from this new ms-dos window u navigate to where your program is located, and simply type its name (*.exe)
    blipp
    Fear leads to anger, anger leads to hatred, and hatred is the path to the dark side
    -Yoda
