  1. Is there any way to load an m2v into cinema craft encoder? If not, I am stuck using TMPGEnc and ReMPEG2. Thanks
    True Story
  2. if i was you i wouldnt settle for them cause cce rocks.
    have you tried dvd2dvdr program.
    you need cce and ifoedit95 installed to run it but its as simple as putting your disc in your drive, run dvd2dvdr, a couple of steps then leave it.
    it rips the film then changes the files to use with cce then re-encodes to a new m2v and ac3 plus subtitles if you want them all automatically.
    thingimijig.
  3. to answer your question, yes you could, you would have to use dvd2avi to make a d2v file that points to your mpv. just load the mpv in to dvd2avi and save. take that file and write it in your avs file that gets loaded into cce.
    I also agree with thingimijig, dvd2dvdr does rock but you have to start using the program with a movie in your dvdrom drive. as far as i know you can not load files off the hardrive to get it to work.
