what is the best converter for me turning a avi to mpeg. and if the file is to long can i split the file and then convert them both or convert and then split.
Already
I use TMPGenc have a look round the forum you will find alot of diffrent programs but this one i think is the best.
I would recomend VDub and TMPGEnc.
For more info check the guides @ http://www.vcdhelp.com/convert -
Sorry i miss read your post..... Still using TMPGenc yes you will have to split the movie in half or at whatever point that will fit onto the size of your cd-r. Full instructions on what to do are on the web.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
