I'm trying to create an XVCD from a DVD (NTSC film) source, one that contains nonstop action. Even with stationary subjects, the camera is in constant motion. I'll be playing the XVCD on a Panasonic RV32 DVD player, which has a maximum data rate of about 2500 Kb/s for a CD-R/CD-RW source. What would be the best TMPGEnc settings to minimize motion artifacts? I'm willing to accept a standard VCD pixel resolution if necessary. The program only runs about 30 minutes so the final file size isn't the first consideration. Thanks in advance.
Basically its all about bitrate. The higher the bitrate, the less compression artifacts you will see. Lowering the resolution (for a specific bitrate) will allow 'more bits per pixel' for want of a better description and will help in terms of blocks etc but its really up to you if it looks better than the higher res version. Using the 'soften block noise' option in Tmpgenc will reduce blockyness at the expense of picture sharpness. Basically the best bet is to do a few test encodes of short clips with different settings until you find waht you like best.
Hope this helps.
Attn: HC Encoder Experts/Optimized Settings?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2011, 21:11 -
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 15:30 -
Mpeg4 Settings for TMPGenc give poor quality for motion.. see pic's
By drewzor in forum Video ConversionReplies: 14Last Post: 13th May 2009, 08:37 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11 -
Optimized Conversion between YUV and RGB
By Dave1024 in forum ProgrammingReplies: 14Last Post: 27th May 2008, 01:40
