Hi,
was wondering if anyone has had any luck encoding from a divx or .mov to a vcd using the fast mpeg 1 encode setting for NTSC.
I have converted a dvd to a vcd using it and it worked ok, but it was PAL and i know that its NTSC that gives problems usually.
Results 1 to 1 of 1
You better believe it :)
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 05:11 -
ffmpeg converts DV .mov to .avi, results run 5 times too fast
By sybariten in forum LinuxReplies: 1Last Post: 13th Jun 2008, 14:48 -
[SOLVED] 'fast action' with ffmpeg or Cinelerra?
By jdetwile in forum LinuxReplies: 2Last Post: 25th Mar 2008, 06:20 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 03:55 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 21:43
