when i save project, there is supposed to be the VOB, D2V & WAV but all i get are the d2v and the wav. heres what i do -
file>open. i search for the vob files in the dvd and open the 1st one. a window pops up showing that i've selected all 8. i press ok and select the audio track and output method. i make a new folder to save these in and save project, but only get the 2 files. is there anything i'm doing wrong?
Originally Posted by asdf
you have to rip the VOB files to your harddrive first..
use smartripper or dvddecrypter -
ohhhh.....i thought DVD2AVI was a substitute for smartripper. ok thanks but when i open smartripper, a window pops up saying no ASPI-Adapter available. should i just ignore this?
Sorry dude, i dont use smartripper, DVDdecrypter for me.. But maybe you can drive to update your ASPI drivers.. Do a search for Nero ASPI on google, and you should find it.Originally Posted by asdf
Asdf, I use smartripper and like you I get the popup no aspi adapter available. Yes you should just ignore this, I do and every time my dvds are ripped to my hd no problems.
Hope this helps, Benge.
Problems ripping my DVD
By KayAt in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2009, 16:33 -
Ripping Problems
By pepegot1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 23rd May 2008, 08:15 -
Problems ripping this...
By EliteMarine in forum DVD RippingReplies: 7Last Post: 29th Apr 2008, 22:18 -
Having ripping problems
By ezzye23 in forum DVD RippingReplies: 3Last Post: 25th Jun 2007, 12:30
