I am not really sure how to use the KVCD templages for tmpenc. I have downloaded the KVCD-LBR-11-12-2002-352x240-_NTSCFilm_-PLUS.mcf file and copied it to the tempenc template folder. Are there any step-by-step tutorials or guides on how what to do.
Thanks for your kind cooperation.
Kizer
Results 1 to 9 of 9
Originally Posted by kizer8
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
Where would I start if I already have an .avi that I want to convert to mpeg.
Thanks.
Kizer -
where to start you are real close http://www.vcdhelp.com/forum/userguides/84759.php
Thanks isogonic, but I was looking more for help on using the kvcd template if you already have an avi.
Thanks.
Kizer -
Thanks, but this still doesn't explain how to use the kvcd templates to fit a movie on 1 cd.
Thanks.
Kizer -
open tmpg, hit load, seard for the file you have the template on, hit this template, and chazan... you have the kvcd template enabled. if you want all the file in one cd (and it's more than 60 minutes), you can do it in the setting tab, then "advanced" and then in "source range".
it's not that hard.
now, all i said here (which is the very basic) you could learn by surfing through tutorials. if you want to understand and make a good job in your dvds/vcds/svcds, you could try the tutorials first.
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 15:37 -
MPG to KVCD HELP
By G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 06:00 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 11:08 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 20:05
