two different questions, so the one i'll post here, the other one in 'players'...
got an avi file that plays back with wrong colours, appearently spread over four quadrants, funny thing is: it played well before... it might have been a windows update that killed *something* but haven't got a clue... might be a codec issue as well...
funniest thing: it plays well in virtual dub, but not under the media player or for example cinemascope
yet i need to convert this file, to edit it, and (you guessed it) currently the editor messes up as well... is there an easy fix beyound re-coding?
Do you have SMR (Angel portion) installed ? if so get rid of it.
Try streaming another copy out of Vdub, see if it helps. -
ok, solved the issue, appearently, something microsoft did... when updating windows 98 (and NOT installing a new mediaplayer or browser, just windows itself) it managed to mess up some files...
removing the codecs (base codec pack and ffdshow) and reinstalling them helped, but some other programs started to complain... so finally i replaced the winapi32.dll with one provided by ahead (nero) and voila, everything ok again, thanks microsoft... sigh...
Help with colour banding...
By FNi in forum EditingReplies: 6Last Post: 2nd Oct 2010, 21:15 -
Menu Colour
By sambat in forum Authoring (DVD)Replies: 0Last Post: 26th Apr 2010, 08:54 -
No colour on TV screen
By dakota17 in forum Newbie / General discussionsReplies: 8Last Post: 6th Oct 2009, 08:42 -
Subpicture Colour Changes
By sambat in forum SubtitleReplies: 2Last Post: 1st Apr 2009, 20:54 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 19:10
