Hi
i think this is a stupid question, but is there any program that can separate "vocal" and "music" from a song. if yes, can you tell me what program is it.
thanks
Try this program called vocal remover from analog x.
http://www.analogx.com/contents/download/audio.htm
I hope this works to your satisfaction, you can in put a mp3, (using winamp), and output a wav "without" vocal, but good luck, removing vocals from music is a daunting task, and i havent found a pay program that works any better than this free one does. believe me ive tried. -
Heh, usually, I use my Sega Saturn for that. It works pretty darn good too, but I still have to output and record to the comp. The saturn also has a GREAT pitch shift function. Most of those I have seen in WAVeditors do change the pitch, but they also change the length of the track to compensate for it. Not the Saturn. I have made several really cool "Alvin and the Chipmunks" versions of Grunge rock anthems. Heeheehee
Remove vocal from a music video or a song
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 1st May 2016, 21:16 -
Magix Music Maker - function to split vocal tracks?
By Artas1984 in forum AudioReplies: 4Last Post: 11th Sep 2011, 19:52 -
Trying to separate music from the rest of the audio in a video.
By walkerrhodes in forum AudioReplies: 8Last Post: 21st May 2011, 04:18 -
How to rip separate songs from a music dvd...
By lordhutt in forum DVD RippingReplies: 4Last Post: 31st Dec 2008, 14:50 -
How Can I Separate DVD Music & Commentary's Voice?
By Aaron1927 in forum AudioReplies: 5Last Post: 10th Aug 2007, 18:28
