HI all,
I just completed a svcd mpeg with tmpge, encode with no flaws, now when i try to burn with Nero SVCD file, i get a message:
that the file is not Super Video compliant, i do have the plug in set for nero so did i do somthing wrong in tmpge? it wants to encode the file
help
The most common error with Nero and burning (S)VCD's is the MPEG has the wrong frame size and frame rate combined with the wrong (S)VCD format setting on Nero. You must encode the MPEG into the correct frame size and frame rate for the VCD/SVCD and NTSC/PAL so it's compliant.
If the format is wrong or you've set Nero incorrectly then, as you've found out, Nero will try to encode the MPEG to the correct format.
Check the frame size and rate against the destination (S)VCD format. Check the "What is" section of VCDHelp to ensure you have encoded the file into an (S)VCD compliant MPEG.
Stella
getting an error message "burn unsucessful. the pack queue is empty. Muxer
By Glenn VK in forum Newbie / General discussionsReplies: 4Last Post: 17th Apr 2011, 18:57 -
Nero 9.2.5.0 - Can't burn anymore (error message enclosed)
By rock_king_my in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2009, 11:02 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
Cannot burn DVDs, error message
By mataharimata in forum Authoring (DVD)Replies: 27Last Post: 22nd Mar 2008, 07:59 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 02:01
