Hello everybody,
I own a Yamaha DVD-S510 DVD player and I'd have a copuple of questions about it.
First of all I would like to update the firmware: how do I find out which version of firmware I have on my Yamaha DVD-S510, where can I find the latest version and what do I have to do (I have read something somewhere on the Net but I can not remember ...)?
Then I would like to unlock it, that means: make it region free (it is a region 2 unit at the moment). I have tried with <PLAY> 159 222 222 005 255 <PLAY> but it did not work: I had to remove the power cord to switch it off!!
I have read that the unit can be hacked using a one for all 6 remote with the code URC-7560: is it the only way? I would not like to buy a remote I only have to use once ...
Any help would be very much appreciated!
Thank you very much in advance.
All the best
LP
other yamada use 123 play for firmware version or is it play 123?
search www.google.com "firmware" "playername"
Insert your player name where I have put playername.Corned beef is now made to a higher standard than at any time in history.
Hello!
I succeeded in hackung it with my palm pilot.
There is a small prog that transforms it in kinda remote ... 8)
Thank you all
Luca
Samsung BD-E8900 Codefree Hack ?
By kinny187 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2012, 07:48 -
Panasonic DMR-BST701EG Codefree DVD Hack
By kinny187 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Nov 2011, 08:31 -
codefree LG V250
By Beamaus in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th May 2010, 07:57 -
Yamaha DVD-S661
By JCWagener in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Mar 2008, 10:16 -
Codefree DK Digital DK-536?
By bigfuz in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd May 2007, 06:08
