  1. I have a high quality avi that I want a convert to a vcd. I have learned enough through this forum to pull it off & have done it successfuly several times b4 but this time I am getting a lot of purple hues that fade in and out when i play back the converted mpeg. Any help would be greatly appreciated
    D
    Oct 2002
    Rio de Janeiro - Brazil
    It happened to me also, using Virtualdub 1.3.
    []s
    Flavio Bessa
  3. Macrovision problem?
    Panasonic DMR-ES45VS, keep those discs a burnin'
    Oct 2002
    Don't think so, because the origin was a simple .AVI file.
    []s
    Flavio Bessa
  5. sorry don't even know what macrovision is but I have tried converting with vdub & PWI both with the same result
    Dec 2002
    devon UK
    In TMP go to options - environmental settings - VFAPI plugins, and raise the priority of Direct Show Multimedia File Reader to 2 not -2, try running again
