Why can't i load in a d2v file when I try to encode with TMPGEnc Plus using the project wizard during the second step? It gives me a "Error, file is not supported message" But it lets me load mpeg videos for some reason.
"Smoking kills. If you're killed, you've lost a very important part of your life."
you have to download and install the vfapi plug in for tmpgenc to the same folder as tmpgenc itself. also go into options/environmental settings and raise the number to 2
What is the vfapi plug and is it a download? If so, where can I get it?
"Smoking kills. If you're killed, you've lost a very important part of your life." -
you can get it from the same site you got tmpgenc, its called tmpg-freevfp, or something similar. its a download and zipped it should be about 1mb in size
Thanks, I upgraded my version to 2.59 which included the plug, now it works!
AviSynth's WavSource won't load WAVE PCM files
By random in forum AudioReplies: 7Last Post: 7th Aug 2016, 12:31 -
Load AVCHD Lite mts files into VirtualDub?
By MJ Peg in forum Video ConversionReplies: 18Last Post: 1st Aug 2012, 12:28 -
Handbrake unable to scan/load source video files.
By e6bwhiz in forum Video ConversionReplies: 1Last Post: 22nd Feb 2011, 16:44 -
Files slow to load in MPC
By MattG in forum Software PlayingReplies: 6Last Post: 15th Sep 2009, 03:29 -
Here is a test: Storage of a S**t load of HD video files
By Lesley NZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 25th Apr 2009, 12:26
