in tmpgenc there is a setting to reduce block noise...if it is enabled the two boxes have a default number of 35....if you hover on it there will be a little ballon saying that at a higher nimber (max of 100) there will be less block noise. i have set mine to 100 and have done many conversions from dvd and other sources over the years and in my opinion the higher the number the less blocks, i really dont know about that but anyway....does any one know the effects of it or if it is actually better or worse cos i have a hard time telling the difference and if i dont need to do it will it be faster????
Results 1 to 1 of 1
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 15:51 -
Multi-colored block noise bug in Adobe Premiere - DV video
By tat2jr1 in forum EditingReplies: 0Last Post: 23rd Jan 2010, 02:20 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
Reduce noise on low light sources
By cd090580 in forum RestorationReplies: 2Last Post: 17th May 2008, 08:44 -
How to reduce Noise on AVI files?
By Nitro89 in forum RestorationReplies: 2Last Post: 8th Oct 2007, 18:29
