Anyone can tell me how to clip the black edges off a video using VDub?
I mean Iin the help file I found out that it has to do something with the null transform filter but I cant find any clip/crop/trim filter or something..
I know this is a stupid question but I need it...![]()
ThankU
How do you recognize a system running Windows(TM) ?
The reset button is dirty....:D -
when you add null transform or a filter you should see the cropping selection in the bottom right hand corner...just click it and it will give you the box you need to clip top and bottom...any probs email me direct.
to get to null transform select video then filter from the dialouge box...its easy
Thank you guys, I will take a better look around next time I guess....
Solutions for transcoding (and clipping) MP4<->AVI
By urymf in forum Video ConversionReplies: 0Last Post: 31st Aug 2011, 08:26 -
MPEG Clipping
By amriteshvara in forum Newbie / General discussionsReplies: 10Last Post: 6th Aug 2010, 02:29 -
video clipping and cropping tool
By greendesert in forum EditingReplies: 8Last Post: 7th Apr 2009, 05:25 -
Ulead videostudio clipping guide
By Bjs in forum User guidesReplies: 4Last Post: 26th Nov 2008, 14:23 -
Vegas 7.0 clipping problem ? Hmmmm....
By Subucni in forum EditingReplies: 3Last Post: 3rd Dec 2007, 16:20
