I have trouble burning a VCD, it just doesnt work![]()
The mpg seems to be fine, I checked it VirtualDub, and Nero also burns it without any problems. But when I put the VCD into my DVD Player it doesn't start.
Its recognized as a VCD, but the drive just makes scaring sounds and ater a few seconds it stops spinning.
Have you burned it compatibile to the whitebook - using Neros wizzard for creating VCDs? (not just burned the file to disk)
If yes try to create a menu page and see if you can get at least the menu started.How do you recognize a system running Windows(TM) ?
The reset button is dirty....:D -
Hehe, yea, I used the wizard and did not just burn the mpg.Originally Posted by dabavil
I made about 70 VCDs before. But this time is the first time that it didnt work.
Burning MPG and DIVX to a DVD
By OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2010, 22:12 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning mpg files
By batke in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2009, 23:18 -
burning a DVD from MPG files
By nick177th in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 18:36 -
Error burning .mpg files to DL disk
By Slowburn in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd May 2007, 08:11
