Often (nearly, but not, always) when i try to reencode DivX movie to VCD, SVCD or KVCD, the encode process fails regardless of the method I use.
Some examples
- TMPGEnc (2.59) gives a read error when using the AVI directly
AVISynth (2.07 & 2.06)produces a black video with a red error message
Using VDub (1.4.9 & 1.4.13) as a frameserver crashes with the vdub extended crash box
CCE (2.5 and 2.64) sometimes hangs, sometimes gives a read error in the logfile, sometimes gives a windows exception.
My suspicion is the codecs as they are the only common thing, (and DivX5 are more reliable than 3 or 4). I've had a number of different codecs installed - Nimo 5.0 Build 8 (installed and deinstalled several times selecting different options), Nimo 5.0 lite (installed and deinstalled), DivX 5.02 Pro, Koepi XviD, and maybe a few more.
Is there a way of cleaning up the codecs (i.e. completely deleting all trace of them) prior to reinstalling?
Anybody got any good advice about which codecs to install? (3.11 Alpha, 4.0, 5.02 etc)
However, GSPOT and AVICodec both suggest that the codecs are correct?so perhaps it's not the codecs - any other ideas about what might be causing the problem?
Sorry for the long post (I hope it makes sense !!!), but it's starting to drive me mad
My kit is as follows:
Abit KX7-333R
AMD Athlon XP 2000+
512MB PC2700
60GB MAXTOR + 20GB MAXTOR + 60GB WD IDE HDDs
Hercules Prophet-II MX
Creative SB PCI16
Adaptec 2904
Sony SDT-5000
Pioneer DVD-ROM
Matsushita CD-R
Windows XP SP1
Thanks for listening and TIA for any suggestions
Results 1 to 1 of 1
Speeding Up / Clean Up on XP
By tgpo in forum ComputerReplies: 7Last Post: 7th Sep 2009, 21:09 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 15:39 -
CODECS-Too Many? Find and Clean-A/V sync Errors
By mrlewp in forum Software PlayingReplies: 9Last Post: 17th Apr 2008, 06:33 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:52
